MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement
  1. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the screws securing the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Disconnect the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the USB-C board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the USB-C board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
    • Remove the USB-C connector bracket.
  6. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  7. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T4 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
  8. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the USB-C board.
crwdns2935229:011crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
215,235 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
would the steps be the same for late 2016 13 inchs? i don't see a guide for that. also why this so much easier than 2015 guide which is 37 steps lol
Xiaolu Zhu - crwdns2934203:0crwdne2934203:0
Followed steps including pressing the gold button near the battery connector and now my machine will not turn on. Any tips? Tried SMC reset.
Denise C - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 9,221
