Use this guide to replace the USB-C board in a 2018 MacBook Air.
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
Remove the USB-C connector bracket.
Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
Use a T4 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
crwdns2935229:012crwdne2935229:0
would the steps be the same for late 2016 13 inchs? i don't see a guide for that. also why this so much easier than 2015 guide which is 37 steps lol
Followed steps including pressing the gold button near the battery connector and now my machine will not turn on. Any tips? Tried SMC reset.
