Mac mini (2024) Front USB-C Ports Replacement
  1. Mac mini (2024) Front USB-C Ports Replacement, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. Mac mini (2024) Front USB-C Ports Replacement, Create a gap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Keep the Jimmy inserted under the bottom cover.
  3. Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. Mac mini (2024) Front USB-C Ports Replacement, Release the clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Release the clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Release the clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the bottom cover until you feel it snag on a clip.
    • There are four clips total—one at each corner of the bottom cover.
    • Twist the pick to lift the clip out of its slot.
  5. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining clips.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four clips click back into place.
  6. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
    • To disconnect the cable and remove the bottom cover, follow the next two steps.
    • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. Mac mini (2024) Front USB-C Ports Replacement, Remove the bottom cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover.
  9. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
    • Eight 3.4 mm‑long screws
    • Four 2.4 mm‑long screws
  10. Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger into one of the clips' slots on the inner plate.
    • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
  11. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
    • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
  12. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
    • Lift the inner plate and flip it over to expose the wireless module cable.
  13. Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use one hand to secure the wireless module during this step.
    • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
  14. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wireless module cover.
    • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
  15. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger under one of the short edges of the wireless module press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
    • Pry up to disconnect the wireless module.
  16. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the inner plate.
  17. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're following this guide to clean your fan, this is a good time to do so.
    • Remove the four screws securing the fan:
    • Two 2.4 mm‑long Torx Plus 3IP screws
    • Two 7.9 mm‑long Torx Plus 5IP screws
  18. Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
    • Let the fan rest on the chassis and heat sink.
  19. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to peel back the tape covering the fan ZIF connector.
  20. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
  21. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
  22. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan.
  23. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
    • Two 4.1 mm‑long screws
    • One 3.7 mm‑long screw
  24. Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  25. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker over the edge of the chassis to expose its cable and its connector.
    • Rest the speaker on the edge of the chassis.
  26. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
  27. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker.
  28. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws securing the USB-C port cover:
    • Three 2.2 mm‑long Torx Plus 3IP screws
    • One 9.2 mm‑long Torx Plus 8IP screw
  29. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to remove the front USB-C port cover.
  30. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the front USB-C ports press connector.
  31. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the four 4.7 mm‑long screws securing the two front USB-C ports.
    • If you aren't using a flexible adapter, make sure your screwdriver is as parallel with the screw as possible. Apply constant force against the screw to avoid stripping.
  32. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry the front USB-C ports from their recesses in the chassis.
    • During reassembly, gently press the USB-C ports into their recesses until they click into place.
  33. Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac mini (2024) Front USB-C Ports Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front USB-C ports out of the chassis and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
165,497 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2935297:019,996crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 680
