Mac Pro First Generation Optical Drive Replacement
Derek Chan
crwdns2944107:0crwdnd2944107:0Derek Chancrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 6, 2025crwdne2944111:0
5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
Replacing the optical drive is straight forward and all you need is a Phillips head screw driver. Use this guide to replace the optical drive in your Mac Pro.
  • Phillips #1 Screwdriver
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Optical Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mac Pro First Generation Optical Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro First Generation Optical Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mac Pro First Generation Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the optical drive and pull it out of its enclosure.
    To make the pull easier without pluming the whole body over- pull with your fingers and brace your thumbs on the tower chassis above - worked for me.
    Nick Rogers - crwdns2934203:0crwdne2934203:0
    Correction, for pluming read pulling!
crwdns2935229:021crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Derek Chan
crwdns2935283:010/13/14crwdne2935283:0
1.419 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-24, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 6-24, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S6G24
crwdns2935297:019crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - crwdns2934203:0crwdne2934203:0
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - crwdns2934203:0crwdne2934203:0
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - crwdns2934203:0crwdne2934203:0
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - crwdns2934203:0crwdne2934203:0
I am having the same problem did you figure out what was wrong?
Tony Bounsall -
Probably just stuck. I’ve had mine out several times before, but the lever at the back of the case must be open. When it’s closed, it locks it in.
Aquenon -
I am having the same problem . I raised the lever handle no problem---Is there another interlock ?
Chuck Hendricks -
I am having the same problem. The lever arm comes up and stays up no Problem. Is there another interlock to release the optical drive door ?
vamochuck@gmail.com
Chuck Hendricks -
I am having the same problem. Any solution ?
vamochuck@gmail.com
Chuck Hendricks -
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 17,507
