If you're having connectivity issues with your Stealth Pro, or simply want to upgrade your connectivity, this guide will walk you through the replacement process.
Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver. One screw will be hidden under a warranty sticker
Gently pry around the back cover off the with a plastic spudger
Unplug the battery cable from the motherboard.
Unscrew the single screw from the Wi-Fi card using a Phillips #00 screwdriver.
Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
Using tweezers, carefully grab and remove the Wi-Fi card.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Is this a msata card or a m.2 card?
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Hi there , the wifi cable (aux) its not connecting to the card , probaly I have bent it , what problem does it cause because right now I still can use the wifi, and most important thing , where can I buy it and how can change it ? Thanks
