MSI GS60 6QE GHOST PRO 4K RAM Replacement
  1. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 5mm screws with a Phillips #0 bit.
    • Remove the four 2.5mm screws with a Phillips #0 bit.
  2. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After opening the bottom plate, locate the battery and the battery connection.
  3. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery connection carefully from the motherboard, and remove the old battery.
  4. MSI GS60 6QE GHOST PRO 4K RAM Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.5 mm screws from the motherboard.
    Hey guys! I have completed this upgrade and just wanted to add a note for you out there that are planning on following these instructions.
    There is another screw that needs to be removed located at the left vent- inward, towards the battery.
    This is something I didn’t spot straight away and took me a little while to notice.
    Cheers!
    Plamen T. - crwdns2934203:0crwdne2934203:0
  5. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the speaker wire.
  6. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the selected black tab that connects the cable onto the board and then slide out the cable.
    • Be careful not to break the black cover.
  7. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to break the black cover because it can be broken easily
  8. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to break the black cover. lift it up gently
  9. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  10. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  11. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the selected cable
  12. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and unplug the selected cables.
  13. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug it carefully without breaking the black cover.
  14. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unplug the selected cable
  15. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the electronic component by sliding it out and lifting it up after unscrewing the 2.5 mm screw
    • Make sure your unscrew the screw first and unplug the chip from the motherboard. Do not disconnect the wires connected to the chip
  16. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
    • This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
  17. MSI GS60 6QE GHOST PRO 4K RAM Replacement, RAM: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the motherboard from the laptop chassis locate the RAM chips indicated by the red rectangle.
  18. MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MSI GS60 6QE GHOST PRO 4K RAM Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grip the two rectangular Ram components, one at a time, and pull them up from the Motherboard, be gentle. Once this process is complete, you have successfully removed the Ram.
Justin Pelley
crwdns2935283:009/28/17crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S1-G4, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S1G4
Thank you very much for this guide. I’ve successfully managed to replace my RAM with 16GB module.
Ondřej Kyzek - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,176
