MNT Pocket Reform Charger Board Replacement
  1. MNT Pocket Reform Charger Board Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Shut down the laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you've installed an operating system, follow the appropriate steps to safely shut down the laptop.
    • If you've not yet installed an operating system, or the laptop is not responsive, you can shut it down with these steps:
    • Turn on the OLED screen by pressing the Hyper key (diagonal arrow) and Enter at the same time.
    • Use the arrow keys to select Power Off on the OLED screen.
    • Press Enter to shut down the laptop.
    • Disconnect all cables from the laptop.
  2. MNT Pocket Reform Charger Board Replacement, Turn off the standby power: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Turn off the standby power: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small tool, like a SIM eject tool or a bent paperclip, to turn off the standby power switch by sliding the switch away from the headset jack.
    • The standby power switch is located in a small recess on the same side as the headset jack.
  3. MNT Pocket Reform Charger Board Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop on your work surface so the bottom cover, with the regulatory info box, is facing up.
    • Use a Phillips screwdriver to remove the six 4.8 mm‑long screws securing the bottom cover.
  4. MNT Pocket Reform Charger Board Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bottom cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
    • Apply a suction handle to the bottom cover.
    • Use the suction handle to lift the bottom cover off of the laptop.
    • Alternatively, you can use a thin prying tool to lift the cover, or tilt the laptop until the cover falls out.
    • During reassembly, place the bottom cover on the laptop so the info box is opposite the hinges.
  5. MNT Pocket Reform Charger Board Replacement, Disconnect the batteries: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Disconnect the batteries: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Disconnect the batteries: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to damage the lithium-polymer batteries when working around them with metal tools. If the batteries are damaged or deformed in any way, take appropriate precautions.
    • Use a pair of tweezers or your fingers to disconnect the batteries' sliding connectors from the charger board.
  6. MNT Pocket Reform Charger Board Replacement, Remove the batteries: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the batteries: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the batteries: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the batteries out of the frame.
    • During reassembly, install the batteries so the foam stickers face up, the sides of the batteries with wires are towards the hinges, and the wires run towards the middle of the laptop.
  7. MNT Pocket Reform Charger Board Replacement, Disconnect the charger board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Disconnect the charger board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Disconnect the charger board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of angled tweezers to disconnect the two sliding connectors from the charger board.
  8. MNT Pocket Reform Charger Board Replacement, Remove the charger board screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the charger board screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4.8 mm‑long screws securing the charger board.
  9. MNT Pocket Reform Charger Board Replacement, Remove the charger board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MNT Pocket Reform Charger Board Replacement, Remove the charger board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the charger board.
Spencer Pennington
crwdns2935283:009/09/23crwdne2935283:0
19 435 crwdns2915208:0crwdne2915208:0
crwdns2935297:0114crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022 008crwdne2935297:0
crwdns2942667:0crwdne2942667:0 106
