The button panel is what transfers button inputs to the motherboard and controls the system directly without use of a controller. These buttons may be stuck and worn after lots of use, so the removal of the board may be necessary. The board may also need replacing due to damage.
Before beginning, disconnect the DVR from power and unplug all peripheries.
Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
Remove the four 1 cm Phillips screws on the rear panel.
Unplug the two cables from the HDD.
Flip the DVR over so the underside is facing up.
Remove the 1 cm Phillips screws on the lower case.
Lift the HDD up and out of the chassis.
Remove the five Phillips screws that secure the button panel.
Depress the white clip that secures the button panel connector.
Disconnect the white button panel connector.
Release the retaining tabs that secure the button panel ribbon cable.
Disconnect the ribbon cable.
Remove the button panel.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
In the details section, there is no time estimation. It took our group 13 minutes to disassemble the dvr and put it back together.
In the details section it does not list the tools needed.
The Guide took us 4 minutes to complete
Anthony - crwdns2934203:0crwdne2934203:0
