Lorex A-MPX IR Bullet Camera Disassembly
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
Hans
crwdns2935283:010/20/14crwdne2935283:0
1,926 crwdns2915208:0crwdne2915208:0
Mero IT Services crwdns2935289:0Mero IT Servicescrwdne2935289:0
Business
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - crwdns2934203:0crwdne2934203:0
Can you do a disassembly video on Lorex C861MB camera ?
crwdns2942667:0crwdne2942667:0 2,921
