If your Logitech Zone Vibe 100 is having difficulties with the microphone, or you are having a hard time being heard for audio reasons- be sure to follow this guide.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
Pry open both the right earpad and left earpad carefully with your hands.
On the left speaker housing, remove the four 4.5 mm screws with a T3 Torx screwdriver.
Remove the single 3.3 mm Phillips #00 screw.
Remove plastic cover from the microphone hinge with your hands and clean any debris with a microfiber cloth.
Desolder the microphone connection from the PCB.
Remove the microphone.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
