Logitech UE BOOM 2 Battery Replacement
  1. Logitech UE BOOM 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. Logitech UE BOOM 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the D-ring has been removed, remove the rubber port cover.
  3. Logitech UE BOOM 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    • It is not necessary to entirely remove the rubber stripping. Simply popping the cap is adequate.
  4. Logitech UE BOOM 2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue removing the rubber stripping down the side if you intend to replace it.
  5. Logitech UE BOOM 2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. DO NOT OPEN SIDE WITH RED CAP (AS SHOWN IN SOME IMAGES), BATTERY IS ON OPPOSITE SIDE
    • Use a metal spudger to pry up the plastic cap.
  6. Logitech UE BOOM 2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech UE BOOM 2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unseat the battery cable from the retaining posts.
    • Squeeze the small black clip on the battery connector, then lift the connector to unplug it.
    • Slowly pull out the battery, and handle with care.
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:052crwdne2935229:0
Brandon Yowakim
crwdns2935283:001/18/18crwdne2935283:0
1 265 crwdns2915208:0crwdne2915208:0
crwdns2947412:027crwdne2947412:0
what kind of battery ?and do you have a link to buy one
wrig5235 - crwdns2934203:0crwdne2934203:0
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
https://www.joesge.com/products/ue-ultim...
Frederic - crwdns2934203:0crwdne2934203:0
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
Joseph Murphy -
It isn't that hard if you've done a couple of repairs, although you gotta work slow and really make sure you got yourself like 3-4 spudger like items (butter knife) and look at reference images where the tabs are. Btw. You don't need to remove more than the bottom plastics and the plate with 4 screws to change the battery. Managed to change my battery while not damaging a single plastic tab
Lucas Schießl -
crwdns2936751:024crwdne2936751:0 48
crwdns2936753:07crwdne2936753:0 297
crwdns2936753:030crwdne2936753:0 1,217
crwdns2942667:0crwdne2942667:0 138,976
