Logitech Slim Folio Battery Replacement
  1. Logitech Slim Folio Battery Replacement, Open the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Open the case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Open the case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open your case and lay it out flat.
  2. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the two case corners closest to the keyboard with your thumbs and pull them down, away from the iPad.
    • Remove the iPad from the case.
  3. Logitech Slim Folio Battery Replacement, Locate the battery tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Slim Folio Battery Replacement, Locate the battery tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fold the case in half, so the keyboard is facing up.
    • Locate the battery tray.
  4. Logitech Slim Folio Battery Replacement, Open the battery tray: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Open the battery tray: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Open the battery tray: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger or a small screwdriver into the access hole on the battery tray.
    • Push the spudger in, down, and pull the spudger towards you.
    • The battery tray should "click" open.
  5. Logitech Slim Folio Battery Replacement, Remove the battery tray: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Slim Folio Battery Replacement, Remove the battery tray: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of the spudger or a small flat head screwdriver into the top of the battery tray.
    • Push the battery tray out, away from the case, until you can grip it with your fingers.
    • If it's stuck, you may need to push on alternating sides to "walk" the tray out.
  6. Logitech Slim Folio Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Slim Folio Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery tray.
  7. Logitech Slim Folio Battery Replacement, Remove the batteries: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Remove the batteries: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Remove the batteries: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the battery tray over.
    • Use the pointed end of the spudger to push both batteries out of the tray.
    • Remove the batteries.
  8. Logitech Slim Folio Battery Replacement, Reinstallation tip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Reinstallation tip: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Slim Folio Battery Replacement, Reinstallation tip: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To install new batteries:
    • Press one edge of a CR2032 coin cell battery against the contact arm, its text and "+" sign facing up.
    • Press to fully seat the battery.
    • Repeat for the second battery.
crwdns2935229:049crwdne2935229:0
Carsten Frauenheim
153,370 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
Staff
crwdns2935297:023,221crwdne2935297:0
crwdns2947412:020crwdne2947412:0
Excellent instructions. So easy - you made me a hero!
edspecial - crwdns2934203:0crwdne2934203:0
So easy to do. I’m up and running again!
Susan Hallett - crwdns2934203:0crwdne2934203:0
when you put the battery tray back in, you have to push it kind of hard to get it to go all the way in. I didn’t have a spudger but was able to use an ice pick (gently) and then a small flat screw driver.
pdmd - crwdns2934203:0crwdne2934203:0
What if you don’t have a spider? Is there anything else that you can use to open the battery tray?
Kathy Pecsko - crwdns2934203:0crwdne2934203:0
You can use something pointy instead of a Spudger. For example: A pair of scissors ✂️. You can open them with the pointy blade. Thanks!
Cheryl Xu -
crwdns2936751:024crwdne2936751:0 179
crwdns2936753:07crwdne2936753:0 1,224
crwdns2936753:030crwdne2936753:0 5,913
crwdns2942667:0crwdne2942667:0 317,289
