Use this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Anywhere 3 for Mac.
While it’s possible to cleanly remove the feet, you may need replacements if one rips or separates from its adhesive pad.
            Slide the mouse's power switch to the OFF position and unplug any cables.
            Flip the mouse over so the feet are facing up.
            Heat an iOpener and lay it on the mouse feet for about two minutes to soften the adhesive.
            There are small gaps in the rims surrounding each foot. This is where to insert your tool when peeling up the feet.
            Push the tip of an opening pick (or spudger) underneath the mouse foot, into the gap in the rim.
            Slide your pick under the foot and lift to remove it.
            Repeat the process to remove the three remaining mouse feet. If you're having trouble sliding the tool under a foot, reheat it and try again.
            Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
            Peel your new mouse feet off their adhesive liners and press them firmly into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
