Logitech M100 USB Cable Replacement
crwdns2942287:0crwdne2942287:0This guide will detail how to disassemble a Logitech M100 mouse and replace its USB cable. This process is relatively universal, so it can be applied to a number of similar mice.
crwdns2944105:0crwdne2944105:0
Carefully remove the feet of the mouse with an opening pick.
Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
Interessante mas muito básico.
Interessante seria se explicasse o significado das cores
Cabo Verde(Green) -
Cabo Branco(White) -
Cabo Vermelho(Red) - (Julgo ser 5v+)
Cabo Preto Fino(thin Back) - (Julgo ser terra (GND)
Cabo Preto Grosso(thick Back) - (Julgo ser massa Chassi)
É bem mais interessante aprender e saber do que ir comprar já feito.
Mais a mais, temos por vezes a necessidade de o rato tenha cabo curto e não longo (encurtar o cabo)
CarlosAulasEVT@gmail
Take the replacement USB cable and connect it to the mainboard.
Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
To reassemble, follow the steps in reverse order.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
