Logitech K750 Keyboard Battery Replacement
  1. Logitech K750 Keyboard Battery Replacement, Turn off the keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, flip the keyboard's power switch into the OFF position.
  2. Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the entire keyboard over, keys facing down.
  3. Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ML2032 rechargeable coin cell battery is located in a tray at the back edge of the keyboard.
    • Insert the flat end of a spudger into the gap between the battery tray and the top surface of the keyboard.
    • Pivot the spudger down, towards the top of the keyboard, to begin to pry the tray out of its cavity.
  4. Logitech K750 Keyboard Battery Replacement, Remove the battery tray: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to push the battery tray out and away from the keyboard.
    • The tray is held in by small "ears" and may take a significant amount of force to dislodge.
    • If you're having trouble, use the end of a spudger or a flat blade screwdriver to "walk" the tray out, pushing on alternating sides instead of directly in the middle.
    • Remove the battery tray.
    • During reassembly, firmly push the battery tray into its slot until it clicks into place.
  5. Logitech K750 Keyboard Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K750 Keyboard Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the battery out of the tray to remove it.
    • Note the battery orientation—it can only go in one way. Set the battery into the tray with side with the text and the "+" sign facing down.
    • Use only a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable.
crwdns2935229:0210crwdne2935229:0
Carsten Frauenheim
155.914 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
crwdns2947412:095crwdne2947412:0
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - crwdns2934203:0crwdne2934203:0
My sentiments, exactly!
Melinda Mcvay -
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - crwdns2934203:0crwdne2934203:0
Thank You! That did work much better!
Matt Anderson -
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers -
crwdns2936751:024crwdne2936751:0 33
crwdns2936753:07crwdne2936753:0 281
crwdns2936753:030crwdne2936753:0 1,909
crwdns2942667:0crwdne2942667:0 281,283
