crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
crwdns2918348:0crwdne2918348:0
crwdns2942335:0crwdne2942335:0
crwdns2948837:0crwdne2948837:0
crwdns2948839:0crwdne2948839:0
crwdns2959928:0crwdne2959928:0 ↓Use this guide to safely remove and replace the battery in a Logitech K750 Solar wireless keyboard.
Note: The K750 Solar requires a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable. You can also use a LIR2032 rechargeable battery as well.
Before you begin, flip the keyboard's power switch into the OFF position.
Flip the entire keyboard over, keys facing down.
Insert the flat end of a spudger into the gap between the battery tray and the top surface of the keyboard.
Pivot the spudger down, towards the top of the keyboard, to begin to pry the tray out of its cavity.
Use the flat end of the spudger to push the battery tray out and away from the keyboard.
If you're having trouble, use the end of a spudger or a flat blade screwdriver to "walk" the tray out, pushing on alternating sides instead of directly in the middle.
Remove the battery tray.
Push the battery out of the tray to remove it.
crwdns2935229:0213crwdne2935229:0
crwdns2947412:095crwdne2947412:0
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My sentiments, exactly!
Melinda Mcvay - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank You! That did work much better!
Matt Anderson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
