If your Logitech K345 keyboard's on/off switch is no longer functioning properly—whether it's stuck, unresponsive, or malfunctioning—this guide will walk you through the process of replacing it.
Before starting, make sure to power off your keyboard and disconnect it from any power source during the repair.
Remove the thirteen 5.3 mm screws from the back of the keyboard using a Phillips #0 screwdriver.
Pry up the corner rubber pads using a Jimmy.
Remove the two 5.3 mm screws from the corners with a Phillips #0 screwdriver.
Use your hands and opening picks to remove the back of the keyboard.
Pry open the sides holding the On/Off button using an opening pick.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
