Logitech H800 Wireless Headset Battery Replacement
  1. Logitech H800 Wireless Headset Battery Replacement, Turn off the headset: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shift the power switch down to the OFF position to turn off the headset.
    • The power switch is located on the right ear cup.
  2. Logitech H800 Wireless Headset Battery Replacement, Rotate the battery cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement, Rotate the battery cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two fingers or your palm to rotate the battery cover on the left ear cup counterclockwise.
    • The indicator on the battery cover should point to the right, protruding circle on the headset when the battery cover is unlatched.
  3. Logitech H800 Wireless Headset Battery Replacement, Remove the battery cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the left ear cup down to remove the battery cover.
    • To reinstall the battery cover, line up the arrow on the inside of the ear cup with the one on the battery cover.
    • The ear cup arrow is located at the top of the battery compartment above the battery. The battery cover arrow is located on the inside top edge of the cover.
  4. Logitech H800 Wireless Headset Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is still connected to the headset by a cable connector at the top of the battery recess. Do not try to completely remove the battery before disconnecting it.
    • While removing the battery, keep it as close to the recess as possible to prevent straining the cables.
    • Use your finger to lift up the right side of the battery about 0.5 cm (when the battery cables are oriented up).
    • You only need to lift it high enough to be able to pull it out of the recess.
  5. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery to the right and away from the ear cup to remove it from the recess.
  6. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the battery 90 degrees clockwise so that it rests on the left side of the ear cup.
  7. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingernail to pry up the edge of the battery connector resting against the flat clip enough that the whole connector pops out of the clips securing it.
    • During reassembly, place one edge of the battery connector under the large upper clip, then press down on the opposite edge to fully seat it.
    • Make sure the battery connector is oriented correctly. The wider part of the battery connector should fit between the left and right flat lower clips.
  8. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the headset on your work surface so the control switches face up.
    • Place the battery on the surface so the cables face up.
    • Place the battery as close to the ear cup as possible to avoid straining the cables.
  9. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the battery connector socket, pull the battery connector out.
    • Hold the battery connector socket and battery connector by their plastic frames and not by their cables to prevent damaging them.
    • If necessary, pull the battery connector with a rocking motion to "walk" it out of its socket.
    • You may need to use your fingernails to pull the battery connector out by the shelf near the cables.
    • When inserting the battery connector, make sure it is oriented correctly. The red cable on the battery connector should line up with the red cable on the battery socket.
  10. Logitech H800 Wireless Headset Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the headset.
    • This headset has a plastic reinforced battery pack. You can reinstall the original battery if needed.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech H800 Answers community for help.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
48.617 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Thank you, I thought it would be easy to figure out, however, your guide saved me time and encouraged me to do this myself.
Mike D.
Mike D - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 6,375
