Have the buttons on your controller been through enough wear and tear? If so, here is the guide to help you with that. All you need is a Phillips #1 driver head, and a pry-tool. This guide will help you replace the buttons on your Logitech Gamepad F310.
The buttons is the input for controller to transmission's to pc for gaming purpose. The buttons are necessary for controller to play the gaming because it will not work if the buttons aren't working property. So that is reason to replacement for the buttons.
No special tools or skills are required.
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Press along the seams of the controller and gently pull the front and rear case apart.
Remove any buttons that need replacement.
You're all finished! To reassemble your device, follow these instructions in reverse order.
Any idea where I can get the d-pad rubber dome replacement part?
