This guide will teach you how to replace the power cord of your device. It's a relatively easy process, and you won't be needing any special skills.
Turn over the keyboard and remove the three screws using a Phillips #0 screwdriver.
Remove the USB from the keyboard.
holy crap you skipped a TON of steps
This is fake.
Make sure the cord tab is not broken.
If the cord tab is not broken, close it back.
Hello,
Where can I find a replacement USB cord ?
My board works fine but sometimes disconnects before the power cable is really used. I just want to change that cable
Yeah there is not problem replacing it but to find the cord itself. Cant seems to find replacement on the web.
INACCURATE; So far I have identified this keyboard has Seven backplate screws - three pictured, two opposite, two hidden beneath the extending blue element. How is the backplate removed?
Stone Dauhg - crwdns2934203:0crwdne2934203:0
Yeah this doesn't seem right at all. They even show the PCB in the next pic. Clearly more screws. 7 across the top and 5 at least on the bottom. I still can't pullit open. Came here figuring I'd see what I'm missing.
Jeffrey Scott - crwdns2934203:0crwdne2934203:0
Just for anyone else annoyed by the incredible lack of info. I think there are 15 screws. First unscrew the smaller bottom part which is the underneath of the palm rest. The left, middle, and right rubber feet there are concealing a screw each. Once that part is off it'll reveal 5 or 6 (can't remember exactly) that are part of the main back piece were trying to remove. Theres also two screws hidden by the blue slide-y thing.
Regardless.... a few more than 3....
WildLicorice - crwdns2934203:0crwdne2934203:0
