Logitech G502 Proteus Core Cable Replacement
  1. Logitech G502 Proteus Core Cable Replacement, Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement, Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a hairdryer to heat three mouse feet briefly.
    • Each mouse foot should take 7-8 seconds to heat up.
  2. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mouse feet gently.
    • Avoid bending the mouse feet.
  3. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the four 12.5 mm screws.
  4. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry open the bottom case.
    • A screwdriver is shown in the photo but screwdrivers shouldn't be used for prying. They might accidentally damage internal components with a slip.
  5. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Raise the tabs to disconnect the ribbon.
  6. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the pin and remove the scroll wheel assembly.
    • Take out the two springs under the scroll wheel assembly.
    • Be careful when lifting the scroll wheel assembly. Do not lose the two specified springs.
  7. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew five 12.5mm screws from the motherboard.
  8. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the tabs lock on each side so you can disconnect the ribbon.
    • Disconnect the PCB from the mouse cable.
  9. Logitech G502 Proteus Core Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Proteus Core Cable Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the plastic piece.
    • Remove the mouse cable.
crwdns2935229:09crwdne2935229:0
Sen
crwdns2935283:009/19/21crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
York University, Team E-13, Melo-Thaiss Fall 2021 crwdns2935289:0York University, Team E-13, Melo-Thaiss Fall 2021crwdne2935289:0
YORK-MELO-THAISS-F21SEG13
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
Black.Technician - crwdns2934203:0crwdne2934203:0
If you are careful enough, you don't need to remove the side button ribbon.
Yueh Tse Chen - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 9,357
