Logitech G502 Lightspeed Feet Replacement
  1. Logitech G502 Lightspeed Feet Replacement, Switch the mouse off: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Switch the mouse off: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, flip the power switch into the OFF position.
  2. Logitech G502 Lightspeed Feet Replacement, Heat the mouse feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Heat the mouse feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat an iOpener and apply it to the mouse feet for one minute.
    • You may use a hair dryer or heat gun. If you do, set it to the lowest temperature setting and apply heat for 10 seconds.
  3. Logitech G502 Lightspeed Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick underneath the front foot at the gap in its recess.
    • The mouse feet are made of two layers. Make sure you insert the pick under the bottom layer to completely remove the foot.
    • When possible, grab with your fingers and slowly pull to peel it off completely.
  4. Logitech G502 Lightspeed Feet Replacement, Remove the front right foot: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the front right foot: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the front right foot: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick underneath the tiny front right foot at the gap in its recess.
  5. Logitech G502 Lightspeed Feet Replacement, Remove the rear foot: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the rear foot: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the rear foot: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick underneath the rear foot starting at the gap in its recess.
    • When installing a new foot:
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  6. Logitech G502 Lightspeed Feet Replacement, Remove the left foot: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the left foot: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the left foot: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick underneath the left foot at the gap in its recess.
  7. Logitech G502 Lightspeed Feet Replacement, Remove the sensor foot: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G502 Lightspeed Feet Replacement, Remove the sensor foot: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick under the front point of the sensor foot. Keep the pick at a steep angle relative to the mouse to get under the foot's adhesive.
    • Make sure to keep the sensor lens free of any adhesive.
    • Remove the sensor foot.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
127,880 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,143crwdne2935297:0
Any recommendations where can I get new feet and adhesive?
Aleš Ferlan - crwdns2934203:0crwdne2934203:0
You can use a double-sided tape or if you want to buy a replacement, look for G502 Lightspeed Rubber Feet on the aftermarket that sells it
Nicholin V -
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 303
crwdns2942667:0crwdne2942667:0 9,283
