Logitech G29 Driving Force Red Dial Replacement
  1. Logitech G29 Driving Force Red Dial Replacement, Red Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G29 Driving Force Red Dial Replacement, Red Dial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G29 Driving Force Red Dial Replacement, Red Dial: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Red Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove wire connecting the PCB to the base of the wheel.
  3. Logitech G29 Driving Force Red Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G29 Driving Force Red Dial Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit Ph #0.
    • Move the PCB to the side to expose the back side of the red dial. Keep the remaining white cable connected to the secondary PCB.
    • Be careful not to lose the buttons and D-pad because once the PCB was removed they can easily be lost.
  4. Logitech G29 Driving Force Red Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G29 Driving Force Red Dial Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, the black center button was pushed out to reveal 3 small black screws.
    • Using the same bit as earlier, bit Ph #00 remove the three 3.32mm diameter 5mm length screws to release the red dial.
Ben varner
crwdns2935283:011/08/23crwdne2935283:0
400 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Harley Fall 2023 crwdns2935289:0IUPUI, Team 1-3, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S1G3
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,756
