Logitech G29 Driving Force Pedal Replacement
  1. Logitech G29 Driving Force Pedal Replacement, Pedal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by orienting the pedal box onto its underside.
    • Remove the twelve #1 Phillips screws that secure the bottom cover to the pedals.
  2. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining twelve #0 Phillips screws from the bottom cover.
  3. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the pedal, first take out the 2 Allen screws located in the middle of the pedals.
    • You only need to remove the screws out of the pedal that needs fixing. Any others can stay where they are.
  4. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that all screws are loose the back plate should be able to be removed revealing the pedals.
  5. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If pedal is unresponsive start by checking the gear mesh.
    • If gear mesh is not connecting check to make sure everything is tight.
    • If gears are stripped or have broken off get replacement gears.
  6. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If gears are fine check the wire connections.
    • If red wires are loose, resolder and make sure the connection is good.
    • If the black ground wire is loose, tighten it up.
    • If none of these fix the problem, source a replacement pedal.
    What do you mean resolder
    Ranveer - crwdns2934203:0crwdne2934203:0
    Before replacing the sensor, I recommend carefully opening it (if possible) and inspecting the potentiometer. It may look like a board with lines. First, check for any dust or dryness. If the sensor is dirty, spray a small amount of WD-40 or any non-conductive lubricant. Next, inspect the metal parts for dirt and clean them with a brush if necessary. After cleaning, apply a suitable amount of electrical grease to improve conductivity. Once done, reassemble the sensor carefully.
    Most problems occur when the sensor fails to detect inputs due to dirt or insufficient contact. Hope this helps! If you have any doubts, feel free to ask.
    Joel - crwdns2934203:0crwdne2934203:0
    any idea where to purchase new potentiometers?
    Albert Newton Slusser - crwdns2934203:0crwdne2934203:0
Brock Harris
crwdns2935283:009/16/22crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G5
crwdns2935297:013crwdne2935297:0
Hola. Tengo un problema en el conexionamiento desde los potenciometros hasta el conector DIM9. ¿Alguien puede pasar Esquema Electrico para poder conexionar los distintos cables en los pins correspondientes?
EckoCharliE72 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 83
crwdns2936753:030crwdne2936753:0 316
crwdns2942667:0crwdne2942667:0 7,045
