Logitech G27 Optical Encoder Replacement
crwdns2942287:0crwdne2942287:0If your Logitech G27 will not respond properly, even after calibrating, you may need to replace its optical encoder. The optical encoder is a small electronic device that turns the wheel's rotation into an electronic signal for the computer to understand. It isn't too hard to replace, you just need plenty of patience because you'll be taking out a lot of screws! Make sure your wheel is completely unplugged before starting this replacement.
crwdns2944105:0crwdne2944105:0
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
Carefully remove the PCB board from the wheel hub.
Carefully pinch and unplug the large 7-pin connector under the PCB board.
These screws refused to go all the way back in for me, and one of them stripped completely. If this happens to you, you can get replacement screws that are shorter here - https://www.amazon.com/gp/product/B01MFA...
This works for the G27, not sure about the G25 or any other wheels.
Obviously the screws being shorter means the wheel isn't as strongly attached to the base in this direction, so if you have to do this remember not to put unnecessary stress on these screws by pulling the wheel straight off the base.
bro i need new long cable i think and that connector or just replace the whole thing .. i put new grease, screw it more tight by the encoder so it woulnt go to the left .. wheel works verry nice tho all my buttons and shifter pedals wont work now tho the lights works dont know what to do now.. and now i kinda regreat opening it.. my wheel run so good now just these buttons are off not working at all and it kinda screws up midle of the game..
@alexdinpoik I’ve had the same problem when the 7 pin connectors blue and green cables broke off. First, only the blue one was broken which only took the led indicators gradual increase but all buttons were working then when i tried to plug in back, the green one broke off leading to none of the buttons working but the led indicators just working. Now i’ll try to fix it with iron soldering.
okan can u pls share a video of you doing it? so i can do the “copy paste” hahah where can i buy cables and stuff i need for that? whats the name of these white connectors ? im new to this but share me a link to buy. i rather just try to fix it then buy a new wheel since its a great wheel compare to g29 that has bad software and the other wheels are to expensive. g27 cant be found in stores anymore neither and if im gonna buy one it has to be new haha hopefully u can share some knowlage thanks!
Where i can Buy the 7 pin cable for Main board please
Hey guys!
i broke the 7 pin cable anyone know where can is buy it? Thanks
You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
Remove the wheel hub and push the connector through the center of the hub.
The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
The housing cover can be set aside until you put the wheel back together.
need two new black screes abouve the pcb board.. lost them need to know the size since the screws i replace it with was not exact..
Loosen the desk clamps before removing the housing, otherwise you risk breaking something. The housing should come off without having to use any force whatsoever.
Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
I’d do steps 9 and 10 in reverse order, the connectors are much easier to unplug while the board is secured in place.
For removing C-Clamps steps 9-13 are unnecessary.
Unplug the three plastic connectors on the left side of the PCB board.
Unplug the two plastic connectors on the top of the PCB board.
Unplug the three plastic connectors on the right side of the PCB board.
Some of the connectors have locks on them, I would recommend this as a two person job.
I didn't take them off :)
I messed up and broke the cables of the 5 Pin Connector on the right. Can anyone tell me what it’s called so I can buy replacement? The Rest of the cable is stuck in there so I can’t re-use it sadly.
Remove the PCB board after all of the plastic connectors are disconnected.
You can now set it aside.
Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
Remove the PCB board mount and remove the clear plastic piece underneath.
Set them aside until you reassemble the wheel.
After following the prerequisite guide, invert your device.
Remove the four center-most screws from the bottom of the device with a Phillips #1 screwdriver.
Invert your device back to its original position, and completely remove the motor housing from the rest of the device.
Remove the eight screws attaching the metal motor housing to the plastic with a Phillips #1 screwdriver.
Completely remove the motor housing from the plastic.
I found the repair easier to do with the motor still attached to the housing, step 15-16 unnecessary.
Turn the device around, and remove the three screws attaching the left most motor to the metal backing using a Phillips #1 screwdriver.
Completely remove the motor from the metal backing. This will make it easier to move around when replacing the optical encoder.
Remove the white 5-pin adapter from the end of the optical encoder.
Remove the plastic casing by prying it off with a screwdriver or a plastic opening tool.
bonsoir ou acheter les conecteur blanc avec les 5 fils pour volant g27
ou acheter les connecteur blanc avec les 5 fils de couleur du volant g27
Remove the two silver screws from the underside of the optical encoder with a Phillips #0 screwdriver, and the circuit will be free from the motor and ready to replace!
my wheel wont calibrate and sometimes it spits out a “power surge on usb” error and my optical encoder is good, what do i do?
I like this replacement. https://es.aliexpress.com/item/329959435...
At first I didn't calibrate myself. I realised that it has to be fully inserted and satin with the end of the motorbike cylinder, as you can see in the seller's pictures. Then it did calibrate.
My wheel won't calabrat is there any where to buy a circuit board with the two cencers
If your wheel doesn't calibrate.Then check your optical encoder. It's 90 percent of the issue. You can find replacement in the ETSY with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT . They have been made like original, but with more reliable plastic. We fixed our Logitech steering wheel
Ifixit is very clear, there are also more clear instructions in my listing how to install this encoder. It's usually 90 percent of the issues for these wheels. You can find insctruction and buy this replacement at ETSY, search for " Optical Encoder 60 Slot for Steering wheel Logitech G25 / old G27 / Driving Force GT "with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT .We fixed our Logitech g25 with it. Use ifcxit screwdrivers and tools, they are great !
During reinstallation make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
Also make sure that the metal half-circle clip is placed properly inside the slot.
After placing the metal clip in the slot, place the plastic cog on top of the clip and on the rail.
Thank you ! ! ! !
Step 19: If you disassembled the wheel with the wheel in center position, you have to re-assemble it with the gear in center position, not as shown on the picture. At least this is what worked perfectly for me on the G27! While disassembling, I paid attention that everything keeps in center position.
There is also small dot on the gear and small arrow on the track that represent the middle, I would say that this is more accurate method. (on G25)
There is a Timing mark on the face of the linear gear and the round gear, line the timings dots together
What holds the metal clip down
Eddie booth
Be very careful when installing and add new grease mark on it.
crwdns2935229:050crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:035crwdne2947412:0
Where can you get the encoder to replace it?
If your wheel doesn't calibrate.Then check your optical encoder. It's 90 percent of the issue You can find replacement in the ETSY with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT . They have been made like original, but with more reliable plastic. We fixed our Logitech steering wheel
Fixer -
Hello and thanks for the guide. I understand this might be off topic, but would you happen to know the pinout of the7-pin connector in step 5? There is no label on the pins. Thanks in advance for your time.
Very much appreciate your assistance & time putting this together. I Chose the expoxy route. My wheel IS BACK!
Are you sure about Step 19 alignment. Some other guy with G25 says it has to be dead centre alligned otherwise you get blinking lights.And that's exactly what happens to me.
hi! i reassembled mine positioning it all the way to the right, and i have blinking power light and my wheel do not calibrate. what do you mean by dead centre aligned? i have to assemble it back together in center position, is that it?
Hey, really big thanks for this guide! I opened my wheel and found the optical encoder broken as foreseen. Just bought the brass version, but for the first instance I fixed the encoder by wrapping some thin tape around the edges and cut off the rest. worked well, but is not meant for a long time use.
As I managed to make this fault, please add a hint that when rearranging the wheel (reverse step 1+2 the thin wheel button wires love to slip close to the bottom left and right screwholes with the risk to be squezzed between wheel and wheel hub. Now I have repaired the wheel function and wrecked the upper left button function :-)
Gracias a esta guía he podido reparar el volante G27. Muchas gracias.
You can buy a printed version here: https://www.shapeways.com/product/4FDSWS...
It worked great for me, it shipped within a week and I'm using it now for over 2 years without any problems.
2 versions are sold: 30 and 60 slot encoder.
60 slot is for G25 and early G27 later G27 wheels use the 30 slot version.
The three hub screws in step 6 refused to go all the way back in, and one of them stripped completely. If this happens to you, you can get shorter screws here to replace those very long screws - https://www.amazon.com/gp/product/B01MFA...
Also the best replacement in terms of longevity for the encoder disk is the brass ones that you can order here, but shipping takes quite a while - http://cmlaserservice.com/index.html
I tried to 3D print one myself but it didn't work.
Hello, i repaired the old optical encoder. Now when i connect my wheel to PC the calibration works. But then PC doesn't "read" when im stearing. The other buttons are ok. Please help me what to do. Thanks
can you please share me the motor specifications?
Is this questin for me?
yeah ! I need this motor specifications :)
Repaired with this guide, thanks.
For the repair of the optical encoder I used a washer.
not encoder?? Washer??
is it work sameway??
I user a washer to repair the broken optical encoder.
smigolxp -
Excellent guide and thanks for the publication and your help !!!
!!!!Took me a white 2FIX it but!!! LISTEN! !!If Your wheel aiant straight in center with good or new encoder TRY first in windows controllers menu .Wherę IT shows controler. Devices while pointing at your g25,7dfgt Device :Press Ctr+shift and right Mouse to engage wheel calibration. Thank you and You Welcome ;)
Hi everyone. You can buy a replacement from there. Optical encoders available with 30 or 60 Slot. For 30 Slot check out this https://www.ebay.com/itm/264059488231 and for 60 Slot check out this https://www.ebay.com/itm/264059495927
Also I have managed to change the encoder without disassembling the mainboard and bearing housing. Just remove the motor encoder cover and change the encoder. The same way worked on Driving Force GT
Where can I order the optical IR sensor? I’m not getting my drive on without one …
DieCalmerThanASuicideBomber - crwdns2934203:0crwdne2934203:0
If someone tries do do this: Do not do step 9 to 16. It’s completely unnecessary and will just make it harder to assemble again. You can remove the cable and casing as described in step 17 just fine with some fiddling.
If you disassemble it completely as shown in this guide you will have to align the stop gear to the track again (step 19), which just doesn’t work well by visual estimate alone.
Hello
I changed my optical wheel, but after that my g27 doesn’t calibrate : power led is blinking, but the wheel doesn’t make its calibration process as the wheel is not moving… After three attempts, power led is blinking fast and that’s all.
I made a video of this problem : https://youtu.be/hihREK_QC1Q
I thought my optical wheel was too low (or too high) on the engin axis, so I tried to change its position but no effect.
If you have any idea…
I had the same issue. If you have a 3d-printed optical wheel replacement make sure to completely cover it with black marker. It has to be all the way black otherwise light can shine through the spokes and the encoder sends an error which results in the issue you’re having.
So even if it looks black.. just try again with the black marker..
Don H -
how many slot encoder do i need?
Step 15 and 16 can be skipped! You can keep the motors attached to the frame to open up and replace the encoder wheel. (I just did it like that and that works fine)
Good day sir
I have lost the 5 pin adapter
Please help me i am unable to find 5-pin adapter for encoder part online
I want to purchase it
Hey,
I switched the encoder on my g27 with a brass one yet I'm facing another issue. With the old broken encoder, it only calibrated to the right. With the new one, It calibrates all the way from right to left but it doesn't come back to the center. Then it repeats the process 3 times but nothing happens. What could be the issue?
I've read people saying that I need to readjust the black plastic to the center on step 19.. any ideas?
No need to disassemble everything! Stop at step 8. DO NOT unscrew the PCB from step 9. Just unclip the 3 connectors on the right (in red on the attached image), as well as the 2 screws and the connector at the bottom right under the optical encoder of the right motor (in blue on the image). And finally the connector and the optical encoder cover.
Il n'est pas nécessaire de tout démonter !
S'arrêter à l'étape 8.
NE PAS dévisser la PCB de l'étape 9.
Il suffit de déclipser les 3 connecteurs de droite (en rouge sur l'image jointe), ainsi que les 2 vis et le connecteur en bas à droite sous l'encodeur optique du moteur de droite en bleu sur l'image). Et pour finir le connecteur et le cache de l'encodeur optique.
The encoder wheel on my G25 cracked recently, so I bought the metal replacement parts (Encoder wheel and the internal frame, which had also cracked), but no matter what I do I have the problem where the wheel spins clockwise, then anti-clockwise, hitting both bump stops but never returns to centre, the two silver screws in the motor are tight and I've tried multiple USB ports, but problem persists and I can't find anything anywhere is solve it.
Not sure what I did, but taking it apart a dozen times, it seems to have just started working again
Ola , minha placa do econder otico do Force Drive Gt , sou os pinos e agora o volante fica pulando e nã calibra mais , meu encoder é de 60 slots , poderia me dizer se essa placa do G27 é compativel com o volante FORCE DRIVE GT fabriacado no ano de 2007 ? porque não estou consiguindo comprar uma nova , caso contrario perderei o volante .
Ifixit is very clear, there are also more clear instructions in my listing how to install this encoder. It's usually 90 percent of the issues for these wheels. You can find insctruction and buy part replacement at ETSY, search for " Optical Encoder 60 Slot for Steering wheel Logitech G25 / old G27 / Driving Force GT "with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT .We fixed our Logitech g25 with it. Use ifxit screwdrivers and tools, they are great !
Fijar primero el volante en la mesa para evitar desperfectos.
Alpc360 - crwdns2934203:0crwdne2934203:0
Actually It's usually 90 percent of the issues. To fix that you can buy this replacement at ETSY, search for " Optical Encoder 60 Slot for Steering wheel Logitech G25 / old G27 / Driving Force GT "with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT .We fixed our Logitech g25 with it.
Fixer - crwdns2934203:0crwdne2934203:0
