Logitech G PRO Wireless Battery Replacement
  1. Logitech G PRO Wireless Battery Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shift the power switch down to turn off your mouse (when the PRO Wireless label is oriented right-side up).
    • The color behind the switch should be red when the mouse is switched off.
  2. Logitech G PRO Wireless Battery Replacement, Apply heat to the upper mouse foot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you plan to reuse the mouse feet, you'll need to apply heat to loosen the adhesive and remove the feet with minimal bending.
    • Heat an iOpener and apply it to the upper mouse foot for one minute.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage. If you use a hair dryer or heat gun, set it to the lowest temperature setting and apply heat for 10 seconds.
  3. Logitech G PRO Wireless Battery Replacement, Insert the spudger under the upper mouse foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Insert the spudger under the upper mouse foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the upper mouse foot.
    • Each mouse foot has a gap in its recess that you can use to insert the spudger.
    • The mouse feet are made of two layers. Make sure you insert the spudger under the bottom layer to completely remove the foot.
  4. Logitech G PRO Wireless Battery Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger under the length of the upper mouse foot to cut through the adhesive and detach it from the mouse.
    • Work slowly to avoid bending the mouse foot. If the adhesive becomes difficult to cut through, remove the spudger and apply more heat.
  5. Logitech G PRO Wireless Battery Replacement, Apply heat to the lower mouse feet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply the iOpener to the lower mouse feet for one minute.
    • Alternatively, use a hair dryer or heat gun to apply heat for ten seconds.
  6. Logitech G PRO Wireless Battery Replacement, Remove the lower mouse feet: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Remove the lower mouse feet: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the left lower mouse foot.
  7. Logitech G PRO Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger under the length of the left lower mouse foot to cut through the adhesive and detach it from the mouse.
  8. Logitech G PRO Wireless Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure to remove the two remaining lower mouse feet.
  9. Logitech G PRO Wireless Battery Replacement, Adhesive information: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're going to install replacement mouse feet or apply new adhesive, use the flat edge of a spudger to remove the remaining adhesive in the mouse foot recesses.
    • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the mouse feet.
  10. Logitech G PRO Wireless Battery Replacement, Remove the lower case screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven 4.4 mm-long screws securing the lower case.
  11. Logitech G PRO Wireless Battery Replacement, Lift the bottom end of the lower case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Lift the bottom end of the lower case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't try to remove the lower case from the upper case yet. They are still attached by the battery cables and input cable.
    • Lift the bottom end of the lower case about 1 cm away from the upper case.
  12. Logitech G PRO Wireless Battery Replacement, Pull the lower case down: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Pull the lower case down: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lower case has clips on its top edge attaching it to the upper case.
    • Pull the lower case down about 0.5 cm to detach the lower case from the upper case.
  13. Logitech G PRO Wireless Battery Replacement, Swing the lower case away from the upper case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Swing the lower case away from the upper case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Swing the lower case away from the upper case: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery cables and input cable are connected to the bottom right of the lower case (when the PRO Wireless logo is facing you).
    • Swing the lower case left to right away from the upper case.
  14. Logitech G PRO Wireless Battery Replacement, Place the mouse on your work surface: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the lower case on your work surface.
    • Lean the upper case against a sturdy object (such as a box) to prevent straining the cables.
  15. Logitech G PRO Wireless Battery Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful during this step, as the socket is very fragile—don't use extreme force.
    • Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • During reassembly, make sure the battery connector is oriented correctly when you insert it into its slot. The red wire should be on the side where the motherboard is marked with a plus sign (+).
    DO NOT DO THIS. If the tweezers/pliers slip say goodbye to the connector and pretty much the battery.
    Ralph Trocchia - crwdns2934203:0crwdne2934203:0
    The same thing happened to me :'(
    The connector disconnected from the motherboard
    Julian Motyl -
  16. Logitech G PRO Wireless Battery Replacement, Disconnect the input cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Disconnect the input cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger or your fingernail to flip up the small, hinged locking flap on the input cable ZIF connector.
  17. Logitech G PRO Wireless Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the input cable out of its ZIF connector.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  18. Logitech G PRO Wireless Battery Replacement, Remove the upper case: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper case from the lower case.
  19. Logitech G PRO Wireless Battery Replacement, Remove the screw securing the battery plate: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the battery plate.
  20. Logitech G PRO Wireless Battery Replacement, Detach the battery plate: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Detach the battery plate: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery plate is lightly adhered to the battery.
    • Use the flat edge of a spudger to lift up the screw side of the battery plate and detach it from the battery.
  21. Logitech G PRO Wireless Battery Replacement, Remove the battery plate: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery plate from the battery.
  22. Logitech G PRO Wireless Battery Replacement, Remove the battery: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Remove the battery: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement, Remove the battery: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is lightly adhered to the upper case.
    • Insert the flat edge of a spudger under the gap beneath the right side of the battery.
    • Lift up the spudger to detach the battery from the upper case.
  23. Logitech G PRO Wireless Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Battery Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the left side of the battery.
  24. Logitech G PRO Wireless Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the upper case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • If your replacement battery doesn't have preinstalled adhesive, apply a 1 cm by 1 cm piece of pre-cut adhesive to the bottom of the battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech G PRO Wireless Answers community for help.
crwdns2935229:013crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
45,422 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Worked entirely fine for me. Since I bought replacement sliders/feet as well, I just skipped the warming up steps. The glue still separated very easily and overall took me like 10 seconds to remove all feet
Regarding the battery/flex-cable step, I personally removed the flex cable first as it’s much more fragile and less replaceable than the battery cable
I also removed the logic board to clean the area below, it’s pretty straight-forward. The only thing one has to remember is where the on/off switch colors go again during re-assembly. Answer: the blue side is at the bottom (when the PRO Wireless label is readable and NOT upside-down), you can find a photo in step 10
The symptoms I had before the repair were a bit weird, which is why I initially wasn’t sure if it’s the battery or not. Basically, my mouse wouldn’t charge a lot, but also wouldn’t work for a long time while connected via cable. Both of these appear to be fixed now (I’ll try to remember to update this comment if it turns out to be broken)
For a replacement battery, I managed to find an original battery on eBay that was disassembled from a returned mouse. That way I could be sure I’m not going to receive some potentially dangerous knock-off version, which I didn’t want to risk.
Florian Wendelborn - crwdns2934203:0crwdne2934203:0
The locking flap on the input cable ZIF connector just broke in half when I tried this teardown. Would you happen to know where I can buy a replacement, if there's any?
Just Lurking - crwdns2934203:0crwdne2934203:0
It is absurd how hard it is to replace a battery on such a simple device. It should be a simple turn and lock mechanism and Logitech should sell replacement batteries directly to the consumers. I guess this way is more profitable because most people including me will never do it!
Ronaldo - crwdns2934203:0crwdne2934203:0
Anybody know of a good battery to use as a replacement? I searched a while back and couldn't find a source I was confident in.
Jason Tran - crwdns2934203:0crwdne2934203:0
Note to all - I'm assuming the battery must run in series with the power/data cable. So if you are having battery issues (battery not charging) and waiting for the replacement to arrive, you can remove battery re-assemble and use the mouse plugged in/switched off as if it were wired in the interim!
Acadia - crwdns2934203:0crwdne2934203:0
Yea my mouse stopped charging. Battery replacement fixed flawlessly. and yes that ZIF connector does totally suck, it's not just you
Tommy Morgan (Shifty Chips) - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 42
crwdns2936753:07crwdne2936753:0 265
crwdns2936753:030crwdne2936753:0 1,274
crwdns2942667:0crwdne2942667:0 53,659
