Logitech G Cloud Right Joystick Replacement
  1. Logitech G Cloud Right Joystick Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud Right Joystick Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Right Joystick Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Right Joystick Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud Right Joystick Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Right Joystick Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Right Joystick Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud Right Joystick Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Right Joystick Replacement, Right Joystick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G Cloud Right Joystick Replacement, Right Joystick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G Cloud Right Joystick Replacement, Right Joystick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the R2 trigger sensor from the joystick plate; it should stay attached to the console.
  7. Logitech G Cloud Right Joystick Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud Right Joystick Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Spencer Davis
crwdns2935283:001/23/25crwdne2935283:0
535 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Spring 2025 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Spring 2025crwdne2935289:0
WCU-VIRTUE-S25S1G1
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 623
