Logitech Extreme 3D Pro Main Joystick Spring Replacement
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 10mm Phillips #1 screws from the bottom.
    There is a 9th screw that you need to remove near the cable
    gigakoulis - crwdns2934203:0crwdne2934203:0
    I need a wiring diagram for the Logitech 3D Pro, I'm changing the Pots.
    Melvin L. Willms - crwdns2934203:0crwdne2934203:0
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Spring
    • The spring will be covered in lubricant.
crwdns2935229:05crwdne2935229:0
Emanuel Canela
crwdns2935283:001/25/18crwdne2935283:0
1.321 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S7-G1, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S7-G1, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S7G1
crwdns2947412:05crwdne2947412:0
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - crwdns2934203:0crwdne2934203:0
Where can I find a replacement spring?
ande3224@bellsouth.net - crwdns2934203:0crwdne2934203:0
Anyone found a source for replacement springs?
Chandler - crwdns2934203:0crwdne2934203:0
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - crwdns2934203:0crwdne2934203:0
In logitech 3d extreme, the middle joystick loosens over time, there is a slight gap when turning it to the right and left. Is there a solution to this?
haşim kadir yüksel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 150
crwdns2942667:0crwdne2942667:0 13,462
