Linksys WAP 11 Network Port Replacement
  1. Linksys WAP 11 Network Port Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power cables and ethernet from the device.
    • Unscrew the external plastic antennas. There is one antenna on each side of the device.
  2. Linksys WAP 11 Network Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys WAP 11 Network Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys WAP 11 Network Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
  3. Linksys WAP 11 Network Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WAP 11 Network Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
  4. Linksys WAP 11 Network Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
  5. Linksys WAP 11 Network Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is what the device looks like when it is fully opened.
  6. Linksys WAP 11 Network Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WAP 11 Network Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, remove the antenna leads as well.
    • Proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • Once the screws are removed, your motherboard will separate from the housing.
    • Keep these three screws together and separate from the outer case screws.
  7. Linksys WAP 11 Network Port Replacement, Network Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear proper eye protection and other personal protective equipment while performing either action!
    • Turn the main circuit board around and using a soldering iron and desoldering wick desolder the 12 pins that secure the port to the main board.
  8. Linksys WAP 11 Network Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WAP 11 Network Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of needle-nose pliers, squeeze the two black plastic clips that secure the network port to the board. Squeeze and push down at the same time to push the network board out of place and remove it from the board.
    • To replace the network port, line up the black plastic clips and pop a new network port into the holes. Reassemble in reverse order.
Joe M
crwdns2935283:010/12/11crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-17, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-17, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G17
crwdns2942667:0crwdne2942667:0 952
