Linksys WAP 11 Motherboard Replacement
  1. Linksys WAP 11 Motherboard Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power cables and ethernet from the device.
    • Unscrew the external plastic antennas. There is one antenna on each side of the device.
  2. Linksys WAP 11 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys WAP 11 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys WAP 11 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
  3. Linksys WAP 11 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WAP 11 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
  4. Linksys WAP 11 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
  5. Linksys WAP 11 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is what the device looks like when it is fully opened.
  6. Linksys WAP 11 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys WAP 11 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, remove the antenna leads as well.
    • Proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • Once the screws are removed, your motherboard will separate from the housing.
    • Keep these three screws together and separate from the outer case screws.
Javier
crwdns2935283:010/12/11crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-17, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-17, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G17
crwdns2942667:0crwdne2942667:0 1,706
