Lezyne CNC Dirt Floor Drive Gauge Replacement
  1. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful when prying off the face plate, as the edges are sharp.
    • Use pliers to remove the internal gauge mechanics.
  3. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
    • Pull the gauge out of its housing.
  4. Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
    • Place a new O-ring into the hole.
  5. Lezyne CNC Dirt Floor Drive Gauge Replacement, Applying Threadlocker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
  6. Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
    Removing the old face plate and gauge internals was a blast. =) However, Step#6 of the guide above says;
    "Allow at least 30 minutes for the thread locker to set.
    Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it."
    The guide that came with the replacement parts says to "Let the Locktite cure for 1 day before pumping."
    I think I used plenty of Locktite, I tightened the gauge and backed it off 1/4 turn to face the handle, I'm gonna let it cure overnight and hope for the best.
    john - crwdns2934203:0crwdne2934203:0
    Seems to have worked. Next time I will reads all the instructions first. One more thing, "Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it." I don't have any way of testing the highest psi. I pumped to my tires highest psi and waited about 2 minutes and no change, so I'm calling this a successful repair. Thank you very much Lezyne, and specifically Colton Arbuckle for your help. =)
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0636crwdne2935297:0
crwdns2947412:07crwdne2947412:0
i use both gold and silver bracelets because for me, they are both great bracelets to wear;; <a href="https://www.chinamaijin.com/">cnc machining</a>
saif 77 - crwdns2934203:0crwdne2934203:0
Its good  as your other  content  : D,  appreciate it for posting . <a href="https://www.chinamaijin.com/">cnc machining parts</a>
I feel nice about it and love learning more about this topic. <a href="https://certifiedbourbon.com/product/blu...">blue label for sale</a> I will come to your site to find out more and tell my acquaintances about you.
Biplob Chandra Singha - crwdns2934203:0crwdne2934203:0
Nice information and good tips for SEO off-page optimization. I have got good tips to improve SEO off-page Optimization. Thanks for sharing! <a href="https://certifiedbourbon.com/product/pap...>pappy van winkle online</a> please keep it up Maintains!
legalweed suppliers - crwdns2934203:0crwdne2934203:0
I was checking continuously this list and I’m impressed! Extremely useful info especially this blog commenting sites list. <a href="https://mushroomlux.com/product/dmt-cart...>purecybin dmt</a> Thank you and best of luck.
Wonderful post. Thank you for sharing the niche sites that can help me to build high-quality links for my business website. <a href="https://purepoppypodsofficial.com/produc...>dried lunaria</a> Please keep it up Maintains!
Super, thank you for writing this blog. I want to thank you for your time and efforts. <a href="https://www.psychedelicssupply.com/produ...>purple skype</a> These sites surely help me to boost my new blog ranking on Google.
crwdns2942667:0crwdne2942667:0 5,709
