Lenovo Yoga C930-13IKB SSD Replacement
Hanna Lazkani
crwdns2944107:0crwdnd2944107:0Hanna Lazkanicrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kul 19, 2024crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
With this guide, you can replace the SSD (Solid State Drive) currently in your Lenovo Yoga C930-13IKB laptop. An SSD is a newer kind of data storage device that does not have any moving parts, unlike the common Hard Disk Drives (HDD). SSDs are faster, more durable, and use less energy. The SSD can be replaced if it is faulty or if you would like to upgrade it.
The SSD card is easy to access and remove. You only need to remove the back cover to access the SSD, and then remove the fasteners attaching the SSD to the motherboard. For this guide, you will need a plastic opening tool, a T5 Torx screwdriver, and a Phillips #00 screwdriver.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. Lenovo Yoga C930-13IKB SSD Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C930-13IKB SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
    The gap is so small that I wasn’t able to insert anything to pry the cover up. The suction cup tool lifted the cover off easily.
    Thomas Capobianco - crwdns2934203:0crwdne2934203:0
    There is a very convenient spot to begin the prying process. Up by the hinge, where the metal back turns in perpendicular to the edge to get around the hinge mechanism, there is a gap between the cover and the rest of the laptop where it can be pried up easily. From there it is easy to run a tool and widen the gap all the way around.
    Alex Yantis - crwdns2934203:0crwdne2934203:0
    I tried Thomas's suggestion first, and it worked like a charm: the suction cup took it right off.
    Instead of pushing the cup against the laptop I "pulled it flat" and placed it against the back, so it'd just suck onto it. (Didn't want to deform the laptop cover)
    Panopticon - crwdns2934203:0crwdne2934203:0
    Opening this up again to re-seat the SSD ...and find that Alex's suggestion is also very good. I would start with his suggestion and then move to Thomas's if the back doesn't just jump off.
  3. Lenovo Yoga C930-13IKB SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C930-13IKB SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
  5. Lenovo Yoga C930-13IKB SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the left side of the SSD card.
    • Pull gently to the left, horizontal to the laptop.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Hanna Lazkani
crwdns2935283:001/23/20crwdne2935283:0
824 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G5, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G5, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G5
I need to remove the stripped screw on the SSDs non-slot-end because Lenovo tightened it down with a military grade drill. To replace, it wasn’t mentioned which size screw was there.
John Tullos - crwdns2934203:0crwdne2934203:0
Ty for the info but I'm looking to get windows installed onto the blank new hard drive so I can actually run and use it, lol! Unfortunately, the "automatic" registration process didn't work and my product key isn't to be found. In fact, my Microsoft account doesn't even have it registered as a device. But it does have it as a device I loaded apps from the Play Store though. So, there's proof it existed. Anywho, I'm stuck trying to get Windows on it before I re-install the hard drive. Any ideas are more than welcome! Thanks, M.H.
Mac Daditink - crwdns2934203:0crwdne2934203:0
Good guide. I took the following steps and it went quickly and smoothly. Less than an hour start to finish:
1. I purchased a Samsung 980 (not Pro, but should also work).
2. Disabled bitlocker on my old SSD. I also backed up the key for future ref.
3. Downloaded and installed the Samsung SSD Magician and migration tools.
4. Put the new SSD into an external enclosure ($18 on Amazon).
5. Ran the migration software and copied my windows 11 to the new SSD.
6. Shutdown the laptop and swapped the SSDs.
7. Rebooted into windows.
8. Ran the Samsung Magician software and updated the SSD firmware.
9. Done and perfect.
Thomas Harding - crwdns2934203:0crwdne2934203:0
THANK YOU, THOMAS!!! I did exactly these things and now my C930 has been running flawlessly for a week now! It is now, once again, my favorite laptop despite its age. :-) You saved me quite a bit of time.
Notes for others: 1) I didn't do Step 8.
2) Here's the enclosure I ordered: https://www.amazon.com/dp/B0BWXDT8TB?ref...
3) The Samsung Magician software can be found at https://semiconductor.samsung.com/us/con...
Gary Friedman -
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 6,194
