Lenovo Yoga C640-13IML Trackpad Replacement
  1. Lenovo Yoga C640-13IML Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the six 4.60 mm screws securing the bottom panel.
    • Keep the screws organized to make reassembly easier.
  2. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic spudger or opening pick into the seam between the bottom panel and the chassis.
    • Gently slide the tool along the edges to release the internal clips and lift the panel off.
    • Go slowly to avoid cracking or snapping the plastic clips.
  3. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.60 mm Phillips #0 screws securing the battery to the chassis.
    • Keep these screws separate from the bottom panel screws—they’re different sizes.
  4. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
    • Do not pull on the battery wires—only lift from the plastic base of the connector using a spudger.
    • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
    • Lift the battery out of the laptop.
  5. Lenovo Yoga C640-13IML Trackpad Replacement, Trackpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Trackpad Replacement, Trackpad: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate trackpad
    • Use a pair of tweezers to gently pull and disconnect the cable attached to the trackpad.
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • Move the orange cable covering the trackpad.
  6. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the metal shielding tape on both sides of the trackpad.
    • Gently lift off the tape.
  7. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screw driver to Remove the four 5 mm screws securing the trackpad to the palm rest.
    • Keep the screws organized they are very small and easy to lose.
  8. Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Trackpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the trackpad from the top edge.
    • Use a plastic pry tool or tweezers if needed to gently separate it from the chassis.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Isaac Quintero Nunez
crwdns2935283:004/09/25crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-1, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-1, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G1
crwdns2942667:0crwdne2942667:0 97
