Lenovo Yoga C640-13IML Speakers Replacement
  1. Lenovo Yoga C640-13IML Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the six 4.60 mm screws securing the bottom panel.
    • Keep the screws organized to make reassembly easier.
  2. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic spudger or opening pick into the seam between the bottom panel and the chassis.
    • Gently slide the tool along the edges to release the internal clips and lift the panel off.
    • Go slowly to avoid cracking or snapping the plastic clips.
  3. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.60 mm Phillips #0 screws securing the battery to the chassis.
    • Keep these screws separate from the bottom panel screws—they’re different sizes.
  4. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
    • Do not pull on the battery wires—only lift from the plastic base of the connector using a spudger.
    • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
    • Lift the battery out of the laptop.
  5. Lenovo Yoga C640-13IML Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement, Speakers: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 2.2 mm screws securing the silver shield.
    • Carefully lift the shield off and set it aside.
  6. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the speaker cable from the port on the motherboard.
  7. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Along the wire path, locate all metal tape and cables holding down or going over the speaker cable.
    • Carefully peel off the tape using tweezers or a spudger.
    • For any cable that fully go over the speaker cable carefully unplug and move the off to the side, be sure to remember where they plug back into.
    • Once the tape is removed, gently move the blue and white speaker cables to the side to clear access to the speaker and port areas.
  8. Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML Speakers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the speakers simply lift them up for where they rest and pull them out.
    • If the blue and white cables snag on any of the tape be sure to go back and make sure there is nothing blocking or preventing the removal.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cece
crwdns2935283:004/14/25crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-1, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-1, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 88
