Lenovo Yoga C640-13IML SSD Replacement
  1. Lenovo Yoga C640-13IML SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the six 4.60 mm screws securing the bottom panel.
    • Keep the screws organized to make reassembly easier.
  2. Lenovo Yoga C640-13IML SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic spudger or opening pick into the seam between the bottom panel and the chassis.
    • Gently slide the tool along the edges to release the internal clips and lift the panel off.
    • Go slowly to avoid cracking or snapping the plastic clips.
  3. Lenovo Yoga C640-13IML SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.60 mm Phillips #0 screws securing the battery to the chassis.
    • Keep these screws separate from the bottom panel screws—they’re different sizes.
  4. Lenovo Yoga C640-13IML SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
    • Do not pull on the battery wires—only lift from the plastic base of the connector using a spudger.
    • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
    • Lift the battery out of the laptop.
  5. Lenovo Yoga C640-13IML SSD Replacement, SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga C640-13IML SSD Replacement, SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 2.23 screw securing the SSD.
    • Gently slide the SSD out of the socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Isaac Quintero Nunez
crwdns2935283:004/09/25crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-1, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-1, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G1
crwdns2942667:0crwdne2942667:0 172
