Lenovo Yoga 720-15IKB Battery Replacement
  1. Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 720-15IKB Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 720-15IKB Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  4. Lenovo Yoga 720-15IKB Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Yoga 720-15IKB Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull firmly on the battery connector to disconnect it.
  5. Lenovo Yoga 720-15IKB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the case to remove it.
    Before installing the new battery. I recomend doing a battery drain, hold the power button for 30 seconds to discharge any capaciters.
    I ran into an issue where once i pulled the battery out and tried to put either the new or old battery back in. When i would try to turn the laptop back on with the power switch, the keyboard back light would blink every few seconds and nothing would come on the screen at all. Doing a battery drain between pulling a battery and puting a new one in fixed the issue.
    Ryan McLaughlin - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Matthew Bornhorst
crwdns2935283:001/23/20crwdne2935283:0
510 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G3, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G3, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G3
crwdns2935297:025crwdne2935297:0
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
James Smith - crwdns2934203:0crwdne2934203:0
Good guide. Fairly easy project. Getting the battery connector back in on the replacement battery was by far the hardest part. Be patient with it. It took me a few tries, but it slid in fairly easily once it was all lined up correctly.
Mark Haakenson - crwdns2934203:0crwdne2934203:0
Thank you for the great informative guide! ordering my battery and tools now!
justmelendez - crwdns2934203:0crwdne2934203:0
The new battery is not recognized after installation.
The plug is very loose. Is that normal? But I can't plug it in any further
Stefan - crwdns2934203:0crwdne2934203:0
Having the exact same problem. If you've figured it out, please let me know.
Riley -
Hola! Que modelo de conector de batería es?
Como se llama ese modelo de conector?
Gracias
Jose javier - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 14,066
