Lenovo Yoga 710-15IKB Battery Replacement
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
    ¿Son Vdes. conscientes de que están haciendo una mala traducción del inglés? Están traduciendo “remove”, que en castellano se traduce por retirar, como remover, que en inglés se traduce por “stir”. No aconsejo remover los tornillos ni las baterías.
    stuart.medina - crwdns2934203:0crwdne2934203:0
    Be cognizant of which screws come from which locations. I did not notice that three of the screws were longer than the others. I ended up reinstalling mine along the hinge side of the back cover.
    jcorrell68 - crwdns2934203:0crwdne2934203:0
    Thanks for the tip! I’ll add that into the guide.
    Arthur Shi -
  2. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
    Wow, this is extremely difficult. Wondering why Lenovo didn’t provide small grooves to simplify this process. This is my first and last time purchasing a Lenovo. I’ve experienced so many issue with this laptop
    Feleisa - crwdns2934203:0crwdne2934203:0
  3. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
    The ones in mine were a Philips #1
    Phil - crwdns2934203:0crwdne2934203:0
    The screws securing my battery were also PH1. Be careful as it would be extremely easy to strip the heads on these screws using the incorrect size.
    Thanks! I’ll update the step to reflect this.
    Arthur Shi -
  5. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
    There is no latch or anything. Just pull it out gently towards the battery.
    Brian Sheppard - crwdns2934203:0crwdne2934203:0
    I had to put a bit of elbow grease and patience into this step. Looking at the replacement battery as reference help to understand what would work best
    This step made me nervous! I wasn't sure how much elbow grease to use. It took a good firm horizontal yank, holding the cord near the plug. It's probably not a good idea to yank it by grasping the battery.
    Kyrsten Wilson - crwdns2934203:0crwdne2934203:0
  6. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and remove the battery.
crwdns2935229:016crwdne2935229:0
Stephanie Alexander
crwdns2935283:009/28/17crwdne2935283:0
757 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G5, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G5, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G5
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - crwdns2934203:0crwdne2934203:0
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 19,440
