Lenovo Yoga 710-15IKB Battery Replacement
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and remove the battery.
crwdns2935229:016crwdne2935229:0
Stephanie Alexander
crwdns2935283:009/28/17crwdne2935283:0
757 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G5, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G5, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G5
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - crwdns2934203:0crwdne2934203:0
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 19,719
