Use this guide to remove or replace the battery on your Lenovo Yoga 710 laptop.
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
The connector slides out of the metal housing, not up from the board.
Thanks for the comment! I’ve corrected the step.
Remove the battery.
i just bought a battery for my lenovo yoga 710-14ikb from ifixit..and now battery is not detected.
crwdns2935229:020crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
Thank you making this guide for a battery replacement!
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Worked great. thx
Holaa, moltes gracies, m'ha anat de primera.
Salutacions
Thank you for this easy to follow guide to giving new life to my Yoga. The new (ifixit supplied) battery is now installed and seems to perform well.
The step I found trickiest was to remove the battery connector but I did manage.
I really recommend the ifixit tool kit as well. It is has an aura of quality and is a joy to use
I tried this but my commputer doesnt detect the new battery, i tried updating drivers, deleting them and static release. Nothing seems to work. What should i do? The old Battery is detected
