Lenovo Yoga 3 Pro Battery Replacement
  1. Lenovo Yoga 3 Pro Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Hi
    I have a Lenovo Yoga 3 pro - 1370
    I take off the SSD without remove the battery. Is this a problem?
    TKS
    Stanley
    Stanleyslaw Castro - crwdns2934203:0crwdne2934203:0
  5. Lenovo Yoga 3 Pro Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift and remove the battery.
    If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
    Kevin Lawless - crwdns2934203:0crwdne2934203:0
    Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
    Ron Westfall - crwdns2934203:0crwdne2934203:0
crwdns2935229:026crwdne2935229:0
Federico LopezCasildo Jr
crwdns2935283:010/08/15crwdne2935283:0
1,340 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-17, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-17, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G17
crwdns2947412:08crwdne2947412:0
Very good and very easy to understand
barri.smith - crwdns2934203:0crwdne2934203:0
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
Raewyn Dowd - crwdns2934203:0crwdne2934203:0
does this same process work for a lonovo yoga pro 2?
Abi Alexander - crwdns2934203:0crwdne2934203:0
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Erika Mackintosh - crwdns2934203:0crwdne2934203:0
I replaced the battery…easy peasy….but now the icon for ‘battery being charged’ has an X over it; reads….there is no batter…but obviously there is as I type this. It is not holding a charge it seems. It only works if the laptop is plugged in? Any suggestions? Thanks.
Ria Swift - crwdns2934203:0crwdne2934203:0
Having the same problem. Replaced the battery as instructed - process was simple. However, the laptop does not recognize the new battery; I booted up plugged into the wall outlet and laptop saying “no battery installed.” I reconnected the new battery exactly as instructed and as the old battery was connected before. PLEASE HELP!
Keith Ashton - crwdns2934203:0crwdne2934203:0
UPDATE: I uninstalled and reinstalled the battery… and now it seems to be recognized and is now beginning to charge.
Keith Ashton -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 61,852
