After a certain period of time or number of uses, a battery loses how long it can stay alive after a single charge. This guide shows how to replace the battery on the Lenovo Yoga 3 Pro.
            Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
            Slide the plastic opening tool between the base cover and the frame to pry open the computer.
            Slowly go around the entire perimeter of the computer until all edges are loose.
            Remove the panel and place it in a safe location.
            Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
            Carefully lift and remove the battery.
crwdns2935229:026crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Very good and very easy to understand
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
does this same process work for a lonovo yoga pro 2?
Awesome and simple! Thank you!
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
