In the Lenovo Yoga Pro 2, the LCD and the digitizer are "glued" together, meaning that you have to replace the whole screen and cannot replace just the glass.
Open the laptop and remove the two screw covers on either side of the computer near the hinges using either the tip of a flathead screwdriver or a spudger.
Remove the revealed two 3/16” screws using a Phillips #00 screwdriver.
Lift the two plastic bezel pieces off using a spudger.
Using a prying tool such as a spudger, gently lift the long plastic bezel piece away from the screen.
Remove the three 1/8” screws using a Phillips #00 screwdriver.
Gently remove the circuit board and set it aside.
Remove the last 1/8” screw near the middle of the screen using a Phillips #00 screwdriver.
Slide the screen up away from the hinges and lift from the backplate.
Fold the screen over and disconnect the LCD screen cable by lifting up the blue tab and pulling.
Remove the four 1/8” screws using a Phillips #00 screwdriver from the hinge on either side of the laptop.
Using a Torx T5 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
Remove the four 3/16” screws from the top of the laptop near the hinges using a Phillips #00 screwdriver.
Using a metal spudger, lift up the connector by the plastic near the top.
Instructions unclear. More detail needs to be given for this step. On the device I have in front of me it does not seem possible to seperate these clasps without breaking things. Also the bit about at the *top* of the plastic needs to be bolded, I started prying at the under side of the connector before I realised. Every other monitor connection I've encountered uses a similar clip system to the MB and RIO connectors so top is a very important detail, also a photo of the clip once apart is essential so that we can understand how to works.
Carefully remove the hinges and remove the screen.
Instructions are a bit confused. If you have the display without the upper case, you can simply remove the wire harnesses from the back of the display after step 8 (4 connection points), and remove the display. Reinstallation is the reverse of removal. No need to open the main case (lower case) of the system.
crwdns2935229:010crwdne2935229:0
Thanks for the great tutorial! Any part number you can provide for this?
I recently replaced my Lenovo Yoga 2 pro touch display, it was cracked and touch went crazy, the crack was from the side which made it usable by disabling the touch drivers. After a while i decided to replace the screen and get back the touch feature. but now i'm suffering that i cannot use it in tablet mode for the following reasons:
After screen replacement, when lid is closed it thinks that it is in tablet mode and screen stays on and doesn't go to sleep mode as it was before replacement, while if I put it in tablet position screen goes off and it goes to sleep mode thinking it is in closed lid position (i think). if i just lift it up only 2 mm from tablet position it gets back on.
Please advise !!
I tried following these steps in reverse order, but I cant get step 7. I can get the glass placed correctly, but cant get it to slide back into place. Do you have any suggestions to get this step working?
My Y2P camera periodically disconnects when I move the screen at the hinges. Any idea if that cable is replaceable without replacing the screen?
Can you advise on how to replace the leftmost LCD cable on Yoga 2 Pro with digitizer (touch) ?
How can I purchase Yoga 2 Pro touch display? Can I get help?
