Lenovo Thinkpad X201 Tablet Keyboard Replacement
crwdns2942287:0crwdne2942287:0This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
First you push the lock button on the back of the computer from lock to unlock.
Then you hold it on unlocked and slide the battery pack out.
Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
Using your fingers push keyboard forward so it is closer to the screen than it was before
Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
