Place the laptop so that the bottom is facing up.
Slide the battery unlock lever to the right.
Gently pull the battery outwards from the body of the device.
Remove the two screws that hold the RAM door in place using a Phillips #000 screwdriver.
Remove the back panel.
Remove the two screws in the middle panel using a Phillips #000 screwdriver.
Flip the laptop over and open the lid.
Push the keyboard forward from the space bar while applying pressure to lift up the keyboard.
Carefully unplug and disconnect the ribbon cable.
Returning to the underside of the device, remove the six screws that hold the palm rest in place.
Flipping to the front of the device, remove the two screws holding the palm rest in place.
With the top of the device facing you, tilt the device 45 degrees upward to access the clips that keep the palm rest in place.
Using a Jimmy, gently unclip the palm rest from the body of the device.
Starting from the hinge of the device, gently lift the palm rest from the body of the device. Before completely removing the palm rest, unclip the ribbon band underneath the mouse pad.
Return to the front of the device.
Remove the screws holding each of the speakers in place on the left and right sides of the device.
Lift the speakers from the body of the device.
