Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
    More pricesely, screws need to be unscrewed, but not removed, since they stay attached to the back cover. Trying to remove them may damage the small gaskets around the screw shaft.
    Edouard Rossignol - crwdns2934203:0crwdne2934203:0
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
    Good solution, but where do I find the battery?
    Brian Arnold - crwdns2934203:0crwdne2934203:0
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
Alex Shacoski
crwdns2935283:002/10/20crwdne2935283:0
276 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G3, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S22-G3, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S22G3
crwdns2935297:011crwdne2935297:0
When you remove a heasink (or heat transfer pipe) from a chip, shouldn't you re-apply any thermal paste? Surely it had some?
Edward Dekkers - crwdns2934203:0crwdne2934203:0
after pressing power button Cooling fan runs for 2 sec then it stays off . What is the problem ?
Tonmoy Arafin - crwdns2934203:0crwdne2934203:0
Is there any upgrade that one can do to the fan or pipe except new thermal paste? I find it quite loud and inefficient. Isn't there a third-party one which is quieter?
Toaster Roaster - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,199
