Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement
  1. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
    I thank you for these instructions. They were quite helpful and I successfully replaced the fan. There is one thing however. Your instructions stated the following: "Be sure to pull on all of the cables at the same time."
    I disagree. One should never pull the wires. I was able to nudge the one part of the connector loose from the other part that it fit into." I then put the new fan in and gently and carefully pushed the connecting parts together.
    Otherwise, your instructions were clear and to the point. Thank you very much
    ALAN L SILBERLIGHT - crwdns2934203:0crwdne2934203:0
    The image shows prying the cover open at the bottom right. In fact, there are tabs securing the bottom edge to the frame. The cover needs to be pried open at the top edge. Once the top edge is released, the cover can be shifted slightly toward the top of the image to disengage the tabs at the bottom.
    This error, along with the similar error about removing the battery in step 4, suggests that the instructions were written with the laptop in the opposite orientation than what is shown in the images.
    EatCroc3 - crwdns2934203:0crwdne2934203:0
    I also don't believe that the iFixit Jimmy is necessary - in fact, it might scratch up the exterior paint of the X1 Carbon Gen 6. Instead, I find the triangular iFixit picks are more appropriate for the task: iFixit Opening Picks (Set of 6)
    Also, at least for my unit, the lid comes off easily and I only use the plastic picks if there's any resistance and I don't want to risk breaking any of the clips.
    Tai Lam - crwdns2934203:0crwdne2934203:0
  3. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
    The screw holes do not align 100%. Dont tighten all the screws as you re-insert them, leave just a little bit of play so that you can push the battery slightly until all the screws fit nicely, then tighten them. A little bit of DIY wisdom helps here. :-)
    Michael Dauer - crwdns2934203:0crwdne2934203:0
  4. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
    Recommend changing the command language to lifting from the TOP edge, as the BOTTOM edge is secured.
    Alexander Van Auker - crwdns2934203:0crwdne2934203:0
    Thank you, was wondering what I'm doing wrong
    Ash Weber-Campbell -
    Agreed, the original description is misleading at best, wrong at worst!
    Victor Vojtech Terber -
    You forgot to tell people to disconnect the battery from the motherboard before removing…
    Becky - crwdns2934203:0crwdne2934203:0
    Agree with both comments above: lift from top left and top right of battery. This disconnects it and it lifts out and away.
    Marc G - crwdns2934203:0crwdne2934203:0
    In my 6th generation X1 Carbon there are two wires that are routed on the edge of the battery and have to be moved out of the way. These are antenna cables, be gentle with them, kinks and indents change their high frequency properties and may lead to problems with your WIFI.
    Before removing laptop cover you can disable the battery in the bios before beginning work for extra safety. Battery will be re-enabled at next startup automatically.
    Darryl S - crwdns2934203:0crwdne2934203:0
    How do I know the generation of my X1 Carbon?
    Does this batter fit all generations?
    eric gofreed - crwdns2934203:0crwdne2934203:0
    The generation info of Lenovo ThinkPad X1 Carbon is marked on the back cover (i.e., 6th Generation), with shiny black color (ink ?), near the fan's openings.
    The battery's original PN for 6th gen is ASM P/N SB10K97587 (FRU P/N 01AV430), marked visible on the battery (after removing the back cover).
    vsm - crwdns2934203:0crwdne2934203:0
    The #0 Phillips screwdriver furnished with the kit was not well machined; it threatened to strip out the Phillips cross-grooves.
    Fortunately, in my own toolbox I had a robust and well machined #0 screwdriver, and was able to remove the battery screws without stripping the grooves.
    Otherwise, the kit was excellent.
    Roger Mehle - 10/23/23
    Roger Mehle - crwdns2934203:0crwdne2934203:0
    Hi @rogermehle, I'm very sorry to hear about the Phillips #0 screwdriver trouble. If you would like to reach out to our Customer Support team via help.ifixit.com, they will be able to assist you. Thank you for letting us know. We're happy your repair was a success overall : )
    Sarah Westberg -
    Yes top edge lift. Can't they change this?
    Ravi Sawhney - crwdns2934203:0crwdne2934203:0
  5. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Fingerprint Scanner: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
  8. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement, Touchpad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to peel back the black adhesive pad.
    • Be gentle; the black adhesive pad is delicate and may rip.
  9. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lever that secures the cable.
    • Pull the cable out to disconnect the ribbon cable that connects to the touchpad.
    • This is the same procedure for removing most of the ribbon cables.
  10. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 1mm screws that secure the touchpad to the laptop.
  11. Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 6th Gen Touchpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, the touchpad can be removed.
    • The touchpad may even fall out once the screws are removed. Be sure to secure the touchpad before it falls out.
Michael Megna
crwdns2935283:001/23/20crwdne2935283:0
1,415 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G4, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G4, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G4
crwdns2935297:023crwdne2935297:0
Where do I get a new mouse pad after I have taken it off?
Jeremiah Gregg - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 5,769
