Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool or your fingers to pry off the cover.
    Use the plastic tool as seen in the picture (pry at the hinge side) as on the nearside of the laptop are some plastic scoop brackets, so prying at the front will be a lost cause and may cause damage.
    Casey - crwdns2934203:0crwdne2934203:0
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by pulling it directly towards you.
    Before installing the new battery, the attached cables connecting it to the board need to be bent or kinked in a similar manner to how the old battery’s cables were. I looked at the old battery’s cables for an idea of how to bend the new cables.
    Also, I saw how the old battery had some very thin foam attached to the battery (as seen in the photos), and that the replacement iFixit battery didn’t have such foam. I couldn’t figure out a way to remove the foam from the old battery without destroying it, so I went ahead and installed the new battery without it.
    Nhan Nguyen - crwdns2934203:0crwdne2934203:0
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
    On my Carbon gen 2 there was a 5th screw, located just shy right of the two screws to the left in this picture (you can see a recess where mine was). It seems like gen 2 touchpads have this screw, however if you're upgrading to a gen 3 touchpad this screw will be omitted, so don't panic if you end up with 1 screw left over!
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
Eevee Murdock
crwdns2935283:001/23/20crwdne2935283:0
1.134 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G4, White Winter 2020 crwdns2935289:0Cal Poly, Team S18-G4, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S18G4
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
crwdns2942667:0crwdne2942667:0 1,979
