Lenovo ThinkPad T490 SSD Replacement
  1. Lenovo ThinkPad T490 SSD Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T490 SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the battery pull-tab at the top of the connector plugin.
    • Pull the connector straight out in the direction toward the cable.
  5. Lenovo ThinkPad T490 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
  6. Lenovo ThinkPad T490 SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the SSD from its socket.
    • If it requires excess force to remove, wiggle side to side while pulling.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Brenden.Welling
crwdns2935283:009/23/24crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-4, Coppersmith Fall 2024 crwdns2935289:0University of North Texas, Team 3-4, Coppersmith Fall 2024crwdne2935289:0
UNT-COPPERSMITH-F24S3G4
Strongly recommend reading Lenovo's own "T490 and P43s Hardware Maintenance Manual", particularly section "1020 Base cover assembly" which gives a recommended order for prying open the clips. It's pretty easy to apply too much pressure in the wrong place and snap a clip, especially now the plastics in these laptops are getting older.
(It's also possible to remove power by changing a setting in the BIOS instead of unplugging the battery, Lenovo's guide also explains how to do this.)
projectgus - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 138
crwdns2942667:0crwdne2942667:0 781
