There are multiple reasons why you would need to replace the motherboard of the Thinkpad, mostly major hardware failures like, the computer frequently crashing, no power in the computer at all, overheating problems, liquid damage, etc. That being said, the motherboard is one of the easiest parts of the Lenovo Thinkpad to remove. All it takes is four simple steps to remove and the same four steps in reverse order to place a new one in.
Loosen the screws from the base plate.
Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
Insert the iFixit opening tool into the space between the base plate and the chassis.
Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
Grab the edge of the cover and lift the cover away from you.
Disconnect the CMOS battery connector.
Flip up the black locking flaps that secure each of the two ribbon cables.
Disconnect both of the ribbon cables.
Remove all of the screws securing the motherboard.
Lift the motherboard up and out of the chassis using your hands.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
