This guide provides essential steps for troubleshooting and replacing your laptop battery. If you’re encountering power issues or reduced battery life, you’ll find practical solutions to help you identify and resolve these problems.
Laptop batteries are crucial for providing portable power, but they can degrade over time due to charging cycles, heat, and age. To maintain battery health, regularly calibrate, avoid extreme temperatures, and manage charging habits. Proper care can extend your battery's lifespan and ensure reliable performance on the go.
Loosen the screws from the base plate.
Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
Insert the iFixit opening tool into the space between the base plate and the chassis.
Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
Grab the edge of the cover and lift the cover away from you.
Remove the four 3 mm screws securing the battery with a Phillips #000 screwdriver.
Use tweezers or your fingernails to disconnect the battery from its motherboard socket.
Lift up and remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
